Straight S-Cable and angle (L-shaped) S-Cable difference
  • Straight S-Cable and angle (L-shaped) S-Cable difference
‎2018-09-10 12:16 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:05 AM
  • Automation Server
  • Automation Server Power Supply
  • Automation Server I/O Modules
The description in the datasheets / installation instructions may not be sufficient to understand the difference(s) between the two types of S-Cables.
January 2013 Update - The straight connector S-Cable has been discontinued. Refer to Product Announcement PA-00238 for details.
The straight S-Cable (part number SXWSCABLE10001) and the angle or L-shaped S-Cable (part number SXWSCABLE10002) works the same in terms of functionality. Both are 1.5 meters in length. The difference is whether the connectors is a straight out type or an angled type. This will probably affect the installation. See the images below
Straight type
Angle or L-shaped
* Note: The straight S-Cable is currently not available and all existing and coming orders for straight S-cable (SXWSCABLE10001) will be replaced with the L-shaped S-cable (SXWSCABLE10002) until further notice.
Refer to TPA-SBO-12-0004 01 for details.
Tags (3)
  • 8389
  • RobertAndriolo19
  • RyanSuar19
