Specifying Dongle ID when locking license to dongle in Vista 5
  • Specifying Dongle ID when locking license to dongle in Vista 5
  • Cody_Failinger
    Cody_Failinger
  • SESA150559
    SESA150559
  • CraigEl
    CraigEl
  • Sacco
    Sacco
‎2018-09-10 06:12 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:53 PM
Unless the correct format is used when defining a dongle as locking property in https://schneider-electric.flexnetoperations.com web site when activating license, the license will not work.
TAC Vista
Vista 5.x
Defining a dongle as locking property in schneider-electric.flexnetoperations.com web site when activating license.
It is important that the format is entered in the following format: TAC_HL_ID=1234567890. If the "TAC_HL_ID=" part is not entered, it will not work, and you will need to rehost the licenses again, this time using the correct format as stated above.
Complete instructions can be found in Rehosting a Vista 5 License on the FlexNet License Server.
  • 7204
