SmartStruxure integration to StruxureWare Data Center Expert via EcoStruxure WebServices
  • SmartStruxure integration to StruxureWare Data Center Expert via EcoStruxure WebServices
  • RyanSuar
    RyanSuar
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 10:26 AM
StruxureWare Building Operation EcoStruxure Web Services
StruxureWare Data Center Expert 7.2.0
There is a need to have StruxureWare Building Operation pass data to StruxureWare Data Center Expert using EcoStruxure Web Services. StruxureWare Building Operation Web Services is capable of both 'Serve' and 'Consume' functionality. However, StruxureWare Data Center Expert (version 7.2.0) is only capable of Web Services 'Serve' function.
Use Modbus TCP instead of EcoStruxure Web Services if StruxureWare Data Center Expert is required to read from StruxureWare Building Operation.
Tags (3)
  • 13142
  • dce
  • ews
