SmartStruxure Modbus register type for Schneider Electric PM meters register type INT64
  • SmartStruxure Modbus register type for Schneider Electric PM meters register type INT64
  • PeterLarsen
    PeterLarsen
  • Benji
    Benji
‎2018-09-06 09:10 AM
Last Updated: Administrator CraigEl Administrator ‎2023-07-10 05:20 PM
What register type should be used for the type called INT64 in the documentation
  • Modbus
  • PM Energy meter
It is not clear what  Modbus register type should be configured for INT64
For reading the INT64 on this range of power meters the register definition you need to apply is the "64 bit signed swapped".
Note that this register type is not available in Building Operation versions earlier than 1.5. For further information on Modbus Register Types see the Point and Value Configuration EBO Webhelp topic
Tags (2)
  • 17447
  • PeterLarsen23
100% helpful (2/2)
