SigmaX - DLL Registration Failure During Installation
  • SigmaX - DLL Registration Failure During Installation
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 01:40 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 06:45 PM
During the installation of SigmaX, the following error message appears:
Module C:\Sigma\Bin\SigToolsCntrl.dll failed to register.
HRESULT -2147024769. Contact your support personnel.
Selecting "Try Again" repeats the error. Choosing "Continue" allows installation to complete, but SigmaX fails to display Sigma data.
Satchwell BAS & Sigma
SigmaX
The installer attempts to register SigToolsCntrl.dll but fails. This is commonly due to:
  • The DLL already being registered.
  • Version mismatch between Sigma and SigmaX.
  • Missing or corrupted DLL file.
  • Verify DLL Presence
    • Navigate to C:\Sigma\Bin
    • Confirm SigToolsCntrl.dll exists.
  • Check Version Compatibility
    • Ensure the installed Sigma version matches the SigmaX version.
  • Manual DLL Registration
    • Open Run from the Start menu.
    • Type:
      regsvr32 "C:\Sigma\Bin\SigToolsCntrl.dll"
    • Click OK.
  • Unregister DLL (if needed)
    • Open Run.
    • Type:
      regsvr32 /u "C:\Sigma\Bin\SigToolsCntrl.dll"
    • Click OK.
  • Clean Reinstallation
    • Uninstall SigmaX.
    • Delete the SigmaX folder.
    • Run a registry cleaner.
    • Reboot the system.
    • Reinstall SigmaX.
  • Full Reinstallation (if issue persists)
    • Uninstall both Sigma and SigmaX.
    • Delete both folders.
    • Reboot.
    • Reinstall Sigma, then SigmaX.
  1.
  • Satchwell BAS & Sigma
Tags (2)
  • 5561
  • CraigEllis25
