Sigma – Working on Multi-Stage Control Objects Can Cause Controller Lock-Up
  • Sigma – Working on Multi-Stage Control Objects Can Cause Controller Lock-Up
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 01:06 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-23 01:05 AM
Editing Multi-Stage control objects in Sigma may cause the controller to lock up unexpectedly.
Satchwell BAS & Sigma
Satchwell Sigma
The precise root cause of the controller lock-up is currently undetermined. However, it has been observed that certain conditions during editing can trigger this behavior.
To mitigate the risk of controller lock-up when working with Multi-Stage control objects, follow these best practices:
  1. Download the Complete Object File Periodically
    • Before and during editing sessions, ensure you download the full object file to maintain a stable configuration and reduce the risk of corruption or lock-up.
  2. Disable Contingency Logging Temporarily
    • If contingency logging is enabled on the Multi-Stage control object, disable it before making any changes. This has been shown to reduce the likelihood of controller instability.
  • Satchwell BAS & Sigma
Tags (2)
  • 6550
  • CraigEllis25
