Sigma - Values on a Dynaview chart are not correct.
  • Sigma - Values on a Dynaview chart are not correct.
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-07 11:37 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 08:35 PM
Dynaview chart values in Sigma are incorrect when compared to values displayed from an index entry.
Satchwell BAS & Sigma
Satchwell Sigma
When a Sigma Dynaview chart is first opened, it records an initial value. Subsequent updates occur only on a Change of Value (CoV) condition. If the object tolerance setting is too large, minor changes won't trigger updates, resulting in outdated or misleading chart data.
To ensure accurate and timely updates in Dynaview charts:
  1. Close the Dynaview chart.
  2. Adjust the object tolerance setting using the Sigma Object Editor:
    • Reduce the tolerance to a suitable level.
  3. Download the updated object to the controller.
  4. Restart the Dynaview chart.
⚠️ Note: Setting the tolerance too low may cause excessive updates, potentially overloading the controller’s communication resources.
Example Tolerance Settings
Object Type Suggested Tolerance Notes
Temperature Sensor 0.05 Updates every 0.1°C
Change of State (Boolean) 0.5 Reflects binary state (True/False)
Pressure Sensor (Pascal scale) 10 Suitable for rapidly changing values
Tool Available
For bulk updates of tolerance settings across Sigma objects, use the Sigma Tolerance Utility.
👉 Download SigmaTolerance.zip
  • Satchwell BAS & Sigma
SigmaTolerance.zip
Tags (2)
  • 5110
  • CraigEllis25
