Customers have requested clarification on how Enthalpy is calculated within a Sigma Programmable Object.
Satchwell BAS & SigmaEnvironment
Satchwell Sigma
Need for transparency and understanding of the internal formula used for Enthalpy calculations in Sigma.
The Sigma Programmable Object calculates Enthalpy (I) using the following formula:
I = 1.006 * t + x * (2501 + 1.8 * t)
Where:
t= temperature in °Cx= humidity ratio, calculated as:
x = 0.62198 * (í * pdm) / (p - í * pdm)
Assuming standard atmospheric pressure p = 101.325 kPa, the formula simplifies to:
x = 0.62198 * (í * pdm) / (101.325 - í * pdm)
Where:
í= relative humidity (as a decimal)pdm= saturation vapor pressure, calculated as:
pdm = p' = 101325 * 10^A
With:
A = A0 - (A1 / T) - A2 * log10(T) - A3 * 10^(-T / A4) + A5 * 10^(A6 / T)
Constants:
- A0 = 20.82648355
- A1 = 2948.997118
- A2 = 5.02808
- A3 = 29811.33781
- A4 = 32.923061
- A5 = 25.21934913
- A6 = 1302.8503
Temperature in Kelvin:
T = 273.15 + t
Additional Notes
- This formula is based on psychrometric principles and is used to calculate the total heat content of moist air.
- Ensure temperature and humidity inputs are accurate for reliable results.
