Sigma - Popup Menus - Creating a New Menu Command to Open PDF Files
  • Sigma - Popup Menus - Creating a New Menu Command to Open PDF Files
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-10 11:35 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-08 08:23 PM
Users may need to create a custom menu command in Sigma that opens specific PDF files, but no default command exists for this purpose.
Satchwell BAS & Sigma
Satchwell Sigma
Sigma does not include a built-in command to open PDF files directly from popup menus.
To create a new popup menu command that opens PDF files:
Step-by-Step Instructions
  1. Open Sigma System Setup
    • From the Sigma System Manager window, navigate to Sigma System Setup.
  2. Access Popup Menu Commands
    • Select General → Pop-up Menu Commands.
  3. Create a New Command
    • Go to File → New.
    • Enter a descriptive name for the new command (e.g., Open PDF Drawing).
  4. Configure Command Properties
    • Select the newly created command.
    • User Access: If needed, configure access permissions using the Browse function.
    • Built-In Functions: Choose any relevant built-in functions and assign a record name.
  5. Set External Function
    • Executable Path: Enter the full path to the PDF viewer application. Example:
      C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe
  6. Define Command Line Options
    • Specify the command and path to the target PDF file. Example:
      C:\Sigma\Data\Graphics\Drawings\Test File {Graphic Num}.pdf
    • This setup opens a file named Test File X.pdf, where X corresponds to the graphic number associated with the Sigma object.
  7. Insert Formal Field
    • In the Formal Fields options box, select Graphic Number, then click Select to insert {Graphic Num} into the command line.
  8. Save and Apply
    • Save the new command configuration.
    • Add the command to the desired popup menu.
Example Use Case
If a Sigma object has a graphic number of 10, the command will open:
Test File 10.pdf
  • Satchwell BAS & Sigma
Tags (2)
  • 12588
  • CraigEllis25
