Sigma Logging – Impact of Object Name Changes on Logged Data
  • Sigma Logging – Impact of Object Name Changes on Logged Data
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 10:21 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 11:59 PM
A customer has a system that has been logging data for several years. They now need to change the name of an object that is actively being logged. The question arises:
What name will appear in the logs when reviewing historical data using Dataview?
Satchwell BAS & Sigma
Satchwell Sigma
Changing the name of a logged object can raise concerns about data continuity and traceability, especially when reviewing historical logs.
When an object name is changed in the system:
  • The new name is immediately passed to the logging setup.
  • From that point forward, all log reviews—including archived and new data—will display the updated object name.
  • This ensures consistency in log presentation but may affect traceability if historical context is needed.
Important Note:
If maintaining historical naming context is critical (e.g., for audits or legacy references), consider documenting the name change separately or exporting logs prior to the change.
  • Satchwell BAS & Sigma
Tags (2)
  • 13401
  • CraigEllis25
