Sigma - Impact and requirements on an IT network.
  • Sigma - Impact and requirements on an IT network.
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 01:59 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 12:25 AM
Understanding the impact of Sigma on IT networks and its communication requirements.
Satchwell BAS & Sigma
Satchwell Sigma
General information regarding Sigma’s behavior and requirements when integrated into an IT network.
Sigma is designed to be IT-friendly and adheres to several IETF standards, ensuring compatibility and minimal impact on network performance.
1. Standards Compliance
Sigma complies with the following IETF protocols:
  • RFC 791 – Internet Protocol (IP)
  • RFC 972 – Internet Control Message Protocol (ICMP)
  • RFC 826 – Address Resolution Protocol (ARP)
  • RFC 950 – Subnet Mask
  • RFC 1256 – Router Discovery
  • RFC 768 – User Datagram Protocol (UDP)
  • RFC 1058 – Routing Information Protocol (RIP)
2. Network Utilization
  • Sigma typically uses 1–2% of a 100 Mbps Ethernet connection.
3. Communication Model
  • Utilizes peer-to-peer communication.
  • Device communication occurs only when required by the system or user.
4. Standalone Operation
  • Devices can operate independently for extended periods during network outages.
5. Data Management
  • Controllers can be configured to limit the frequency of global data exchanges.
6. Client Polling
  • Sigma Remote Clients poll the Sigma Server to maintain connection integrity.
7. Protocol Usage
  • Server ↔ Controllers/DNNs/ICs: Use UDP messages (size varies).
  • Client ↔ Server: Use TCP messages (size varies).
8. Port Requirements
Sigma uses the following ports:
  • 49152
  • 3614
  • 80
  • 8080
9. Communication Speeds
  • Sigma V53 devices: Communicate at 10 Mbps half duplex.
  • Sigma ARM devices: Negotiate speed starting at 100 Mbps half duplex, then 10 Mbps full duplex, and finally 10 Mbps half duplex.
Additional Notes
  • Sigma’s design ensures minimal disruption and efficient operation within modern IT infrastructures.
  • For firewall and network configuration, ensure the above ports are whitelisted.
  • Satchwell BAS & Sigma
Tags (2)
  • 4862
  • CraigEllis25
