Sigma ICs – Can a Sigma IC-Unifact IC Be Converted to an IC-SNP?
  • Sigma ICs – Can a Sigma IC-Unifact IC Be Converted to an IC-SNP?
  • CraigEl
    CraigEl
  • Gary
    Gary
  • sesa125819
    sesa125819
‎2018-09-06 11:13 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 10:05 PM
A customer has purchased an incorrect type of Interface Controller (IC) — specifically, a Sigma IC-Unifact — and is seeking to convert it to an IC-SNP.
Satchwell BAS & Sigma
Sigma IC / IC3
The request arises due to a mismatch between the purchased IC type and the required application. The customer intended to use an IC-SNP but mistakenly acquired an IC-Unifact.
Unfortunately, conversion between IC types is not possible.
Each IC or IC3 has a unique personality embedded in its hardware, which is tightly coupled with its firmware. Even if the firmware is changed, the underlying hardware personality remains unchanged. This mismatch prevents the IC from functioning correctly in a different role.
Therefore, to ensure proper operation, the correct IC type must be procured from the outset.
  • Satchwell BAS & Sigma
Tags (2)
  • 10882
  • CraigEllis25
