When using the IC_LON Plug-in, an error is reported:
Unknown SNVT Type: nn
This indicates that the SNVT (Standard Network Variable Type) is not supported by the IC3-LON controller.
Satchwell BAS & SigmaEnvironment
Sigma IC-LON Version 1.E
The Sigma IC3-LON controller is designed to work with LONMARK Resource Files Version 11. However, not all SNVT types defined in this version are supported by the controller.
To resolve this issue:
Verify Supported SNVTs
Refer to the IC3-LON Release Notes to confirm which SNVT types are supported. -
Avoid Unsupported SNVTs
If an unsupported SNVT is required, consider alternative approaches such as:- Using a supported SNVT with similar functionality.
- Reconfiguring the device or network to bypass the unsupported SNVT.
Firmware Reference
See the attached document:
📎 Release_Note_4-05 Firmware_IC3-LON.pdf
