Sigma IC-Modbus - Reading 32 Bit Integer values from two 16 Bit registers.
  • Sigma IC-Modbus - Reading 32 Bit Integer values from two 16 Bit registers.
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 12:11 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-07 05:33 PM
How to read a 32-bit integer value stored across two 16-bit registers using IC-Modbus.
Satchwell BAS & Sigma
  • IC-Modbus
  • IC3-Modbus
Prior to firmware release 4.05, IC3-Modbus did not natively support reading 32-bit integer values directly.
IC3-Modbus 4.05 and Later
Firmware version 4.05 introduced support for reading 32-bit values using Function Codes 03 (Read Holding Register) and 04 (Read Input Register).
Supported 32-bit data types:
  • Signed 32-bit
  • Signed 32-bit (swapped)
  • Unsigned 32-bit
  • Unsigned 32-bit (swapped)
  • Float 32-bit
  • Float 32-bit (swapped)
🔹 Note: This is a special case of the “2 register read” and requires two consecutive Sigma object numbers.
Refer to: Sigma - Release 4.06 - Firmware IC3-Modbus Release Note Section 11.4.2 – 32-bit Data Types
Other Sigma Versions (Pre-4.05)
To read a 32-bit integer from two 16-bit registers:
  1. Read both registers into separate Analogue Input (AI) objects.
  2. Combine the values using a programmable object:
    • Multiply the high register by 65536
    • Add the low register value
💡 Example Code Snippet
10 XFlo = POINT 0|64      ; High register
20 YFlo = POINT 0|65      ; Low register
30 ZFlo = (XFlo * 65536.0) + YFlo
40 RETURN VIA TEXT 200 VALUE ZFlo  ; Use a suitable text object
Notes
  • Ensure the register order (high vs. low) matches the device’s Modbus specification.
  • Use Text 200 or a similar object to display the final 32-bit value.
  • Satchwell BAS & Sigma
Tags (2)
  • 8250
  • CraigEllis25
