Sigma Graphics – How to Create and Fill a Shape from Multiple Lines
  • Sigma Graphics – How to Create and Fill a Shape from Multiple Lines
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 12:52 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 09:41 PM
Users want to create a custom shape using multiple lines in Sigma Graphics and fill it with color.
Satchwell BAS & Sigma
Satchwell Sigma Graphics
Shapes created by combining multiple lines into a single object cannot be directly filled with color in Sigma Graphics.
To achieve a filled shape, use the Polygon Tool as a workaround. Although slightly more complex, it allows for color filling once the shape is completed and closed.
Step-by-Step Instructions:
  1. Design the Shape:
    • Sketch your desired shape using lines as a reference.
  2. Use the Polygon Tool:
    • Select the Polygon Tool.
    • Click on each corner of your reference shape to replicate it.
  3. Terminate the Polygon Function:
    • Press the Escape key to end the polygon drawing.
    • The shape may temporarily disappear.
  4. Save and Reopen:
    • Save the graphic.
    • Close and reopen the file.
  5. Clean Up:
    • Delete the original reference shape made of lines.
  6. Connect and Fill:
    • Highlight the new polygon shape.
    • From the right-hand menu, select Connect Closed.
    • Then choose Shape Fill and select your desired color.
Result:
You now have a custom shape filled with color, created using the Polygon Tool.
  • Satchwell BAS & Sigma
Tags (2)
  • 7092
  • CraigEllis25
