Sigma – Delayed Alarms at the Sigma Server
  • Sigma – Delayed Alarms at the Sigma Server
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 03:27 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-22 11:59 PM
Alarms generated by Sigma controllers are sometimes delayed in appearing at the Sigma server. This behavior is inconsistent—manual alarm tests display correctly, but real-time alarms may not appear until other activities are performed.
Satchwell BAS & Sigma
Satchwell Sigma
There are two recommended solutions depending on your network setup:
Option 1: Disable Windows Firewall
If the Sigma server is not connected to the Internet, you can safely disable the Windows Firewall to allow uninterrupted alarm communication.
⚠️ Note: The method to disable the firewall varies by operating system. Use the system's Help feature for guidance.
Option 2: Add a Firewall Exception
If disabling the firewall is not viable, configure a firewall exception for Sigma:
  1. Open Windows Firewall.
  2. Navigate to the Exceptions tab.
  3. Select Add Port.
  4. Enter the following details:
    • Name: Sigma UDP Port
    • Port Number: 49152
    • Protocol: UDP
✅ This allows Sigma alarm messages to pass through even when the firewall is active.
Additional Notes
  • Port 49152 is specific to Sigma and must be configured as a UDP port.
  • Satchwell BAS & Sigma
Tags (2)
  • 7688
  • CraigEllis25
