Sigma 4.05 Log Configuration Not Displayed
  • Sigma 4.05 Log Configuration Not Displayed
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 01:14 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-23 01:00 AM
After upgrading to Sigma 4.05 SEB, the log configurations are not visible in the configuration window.
Satchwell BAS & Sigma
Satchwell Sigma
The LogCNF.rec file was not properly upgraded during the transition to Sigma 4.05 SEB. This results in the log configuration not being displayed.
To restore visibility of the log configuration:
  1. Shutdown Sigma Services
    • Close both the Sigma client and server applications.
  2. Restore the Configuration File
    • Locate a backup of the LogCNF.rec file.
    • Copy it to the following directory:
      C:\Sigma\Data\ServerXXX\
      Replace XXX with the appropriate server number.
  3. Run the Upgrade Utility
    • Execute the Sigma upgrade tool:
      C:\Sigma\BinUtils\SigUpgrade.exe
  4. Restart Services
    • Restart both the Sigma server and client.
  5. Verify
    • Open the configuration window to confirm that the log configuration is now visible.
  • Satchwell BAS & Sigma
Tags (2)
  • 6285
  • CraigEllis25
