Sharing a CO2 sensor between Xenta 102-AX controllers
  • Sharing a CO2 sensor between Xenta 102-AX controllers
  • CraigEl
    CraigEl
  • Sacco
    Sacco
‎2018-09-10 04:56 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 11:03 PM
Several Xenta 102-AX controllers need to have the CO2 sensor shared among them in a LNS environment.
TAC Vista
  • CO2 (Carbon Dioxide)
  • Xenta 102-AX
  • nviCO2
  • nvoCO2sensor
Properly binding a CO2 sensor output to multiple Xenta 102-AX VAVs.
From the Xenta 102-AX VAV that is connected to the CO2 sensor, create a binding from the UnivIn3Sense function block/nvoCO2sensor, to VAV_Controller function block/nviCO2 in the receiving Xenta 102-AX VAVs.
It will also be necessary to set the send heart beats by following Values sent from a 102-AX via SNVT bindings are not making it to the receiving controller.
  • 6683
