Sending alarms to multiple email recipients
  • Sending alarms to multiple email recipients
  • RobertAndriolo
    RobertAndriolo
  • JonGreen
    JonGreen
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2019-05-14 10:53 PM
Not sure how to configure sending emails to multiple recipients when an Input or Area goes into alarm.
Security Expert
  • Security Expert
  • SP-C-WEB
Correct formatting must be used when sending alarms to multiple email recipients.
Separate each address with a semi-colon and surround the entire string with double quotes, see examples below.
Security Expert
Navigate to Events | Actions, create a new Send E-mail Action and add your multiple addresses to the E-mail Address field.
  • "address1@email.com;address2@email.com"Email AddressesEmail Addresses
  • The email address field is limited to a maximum of 128 characters. All email addresses must be within this 128 character limit to be sent correctly.
SP-C-WEB
To add multiple recipient addresses, navigate to Programming | Areas or Programming | Inputs.
  • For an Area, select the Configuration tab and add a recipient email address to the
    command window and use the format:email:"address1@email.com;address2@email.com"
  • For an Input, navigate to the Commands window for your selected input and use the
    format: email:"address1@email.com;address2@email.com"
  • EcoStruxure Security Expert
Tags (4)
  • AdamSteele19
  • AdamSteele20
  • HernanUruena25
  • JonGreen19
