Seeing an error when attempting to log in to Security Expert Web Client.
  • Seeing an error when attempting to log in to Security Expert Web Client.
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
  • HenrikTarpgaard
    HenrikTarpgaard
‎2018-09-10 09:54 AM
Last Updated: Guinan AdamSteele Guinan ‎2022-04-28 06:57 PM
When attempting to login to Security Expert Web Client the below error is seen.
  • The communication object, System.ServiceModel.Channels.ServiceChannel, cannot be used for communication because it is in the Faulted state.
EcoStruxure Security Expert
The typical cause of this error is a mismatch in the security bindings between the SOAP Service and the Security Expert Data Service. For example if you enable the Windows Authentication checkbox in the Security Expert installer but not in the SOAP Service installer (or vice versa) then you have a mismatch.
Either uninstall the SOAP service and update the checkbox selection to match whatever was selected in the Security Expert installer, or follow the instructions under Troubleshooting | Communication Fault/Failure in the SX-WEB - Security Expert - Security Expert Web Client - Installation Guide for editing the config files of the SOAP service to match the Security Expert Data Service.
  • EcoStruxure Security Expert
Tags (5)
  • 19422
  • AdamSteele21
  • AdamSteele22
  • AdamSteele23
  • HernanUruena24
100% helpful (2/2)
