Security Expert not showing event , report generation fails, SQL exception in Windows Event
  • Security Expert not showing event , report generation fails, SQL exception in Windows Event
  • MaximeLaudren
    MaximeLaudren
  • JonGreen
    JonGreen
Lieutenant MaximeLaudren Lieutenant
‎2021-08-13 12:10 PM
on ‎2021-08-13 12:10 PM
Events in the Events monitoring page, and executing the reports fail with an error.
In The Windows event logs, the following entry can be seen:
Could not continue scan with NOLOCK due to data movement.
Security Expert
  • Microsoft Windows Server 2016 and later
  • Microsoft Windows 10
  • Microsoft SQL Server 2012 and later
The message visible in the Event log indicates a corruption of the database.
Security Expert is not able to read data from the database, and cannot write events to the database either.
Any events occurring after the corruption are lost, and not recoverable.
Contact Product Support for assistance as soon as you notice this issue.
  • EcoStruxure Building Expert
