Security Expert Data Service fails to start with error 1067
  • Security Expert Data Service fails to start with error 1067
  • RandyDavis
    RandyDavis
  • AbeMeran
    AbeMeran
  • AdamSteele
    AdamSteele
  • Alan_Wood
    Alan_Wood
Captain AbeMeran Captain
‎2021-10-26 11:16 AM
Last Updated: Guinan AdamSteele Guinan ‎2025-04-07 10:21 PM
Security Expert Data Service fails to start with error 1067: The process terminated unexpectedly
Security Expert
Security Expert Server
  • Port used by the service is blocked or already in use
  • Permission issues with the service logon account
  • Prerequisite .NET Framework is incomplete or not installed correctly
  1. In Windows go to Windows Features and ensure that all .NET Framework items show a check mark to indicate that each sub item has been enabled. See Ensuring Windows features are installed for Security Expert SOAP service for details.
  2. In Windows Event Viewer, examine the Application log, it will typically have an entry with details about the reason for the error.2021-10-21_10-59-06.jpgIn this case, we see an Address Already In Use Exception in the Socket Connection Listener. This is a clue the error is with the network port. The Security Expert data service has been configured to use the default port 8000.
  3. On the server, list the network ports using netstat.2021-10-22_10-07-14.jpg
    We can see PID 5660 is already using the port.
  5. Once the service is identified, take corrective steps to ensure the two services don't use the same port.
  6. Make sure the Windows account the service is using to log on has the appropriate permissions.
  7. If port 8000 isn't being used, first Reboot the Security Expert PC and if the error still persists, uninstall Security Expert, reboot and reinstall.
  • EcoStruxure Security Expert
Tags (8)
  • 1067
  • AbeMeran21
  • AdamSteele25
  • AlanWood22
  • Data Service
  • process
  • terminated
  • unexpectedly
