Search feature in EcoStruxure Building Operation
  • Search feature in EcoStruxure Building Operation
  • CraigEl
    CraigEl
  • SharlinaRe
    SharlinaRe
  • Cody_Failinger
    Cody_Failinger
‎2018-09-11 07:44 AM
Last Updated: Administrator CraigEl Administrator ‎2022-09-07 07:58 PM
How to search for points, names, or descriptions in EcoStruxure Building Operation
Building Operation WorkStation
The EcoStruxure Building Operation search feature can be performed on an entire database or on individual controllers / folders. This can help reduce the amount of time it takes to locate multiple points when creating mirrored points.
How to search for specific names in EcoStruxure Building Operation
  1. Right click on the folder, object, or controller you would like to search in and click "Search. Note: When the search is narrowed down to specific areas of the database it will be able to complete the search faster than performing a full database search."
  2. In the search field type in the name that you are looking for. In this example the search is for snvt*. This will locate all points underneath the controller that begin with snvt in the point name.
  3. After a few seconds, depending on the size of the search area, the results will be displayed in the window to the right.
  4. In order to filter the search further, you can set different search parameters under the search field.
Tags (2)
  • 16149
  • SharlinaRenwall22
0% helpful (0/1)
