Script program halted with "Tried to divide a value by zero" error
  • Script program halted with "Tried to divide a value by zero" error
  • RobertAndriolo
    RobertAndriolo
  • JonGreen
    JonGreen
  • GavinHe
    GavinHe
Commander JonGreen Commander
‎2019-05-09 02:02 AM
Last Updated: Sisko GavinHe Sisko ‎2023-10-24 05:38 AM
A script program status is halted with an error indicating "Tried to divide a value by zero"
  • Building Operation MP-C Controllers
  • Building Operation MP-V Controllers
  • Building Operation RP-C Controllers
  • Building Operation RP-V Controllers
The halted program, or a function used within the program, has within itself a divisor that equals or can equate to zero.  An example would be if using Scan as a divisor - (Err - Lerr) / Scan
Ensure that no divisor within the program or function can possibly become zero.  One way to do this would be to either set the divisor to a value greater than zero prior to using it or add a small value to the divisor.  For example:  (Err - Lerr) / (Scan + 0.00001)
Tags (6)
  • divide by zero
  • GavinHeward23
  • JonGreen19
  • mp-x
  • RobertAndriolo19
  • scan
84% helpful (5/6)
