Schindler Life Reporting
Select a Country
  • Schindler Life Reporting
  • RandyDavis
    RandyDavis
  • JamesMorgan
    JamesMorgan
JamesMorgan Explorer
‎2022-12-13 08:36 AM
Last Updated: CraigEl Champion ‎2022-12-14 03:54 PM
What is Life Reporting?
EcoStruxure Security Expert
Security Expert Schindler Elevator HLI Integration
What function does the Life Reporting feature in a Schindler Elevator HLI Integration perform
Life Reporting is a feature in the Security Expert Schindler Elevator HLI Integration. The life reporting interface is how Access Events from the Schindler system are reported back to Security Expert via TCP port. When enabled, you can receive "floor unlocked" events.
Multiple loggers can be configured for the life reporting interface using the same IP address.
Up to 32 loggers can be configured for the life reporting interface. You can also use Schneider Electric card readers for elevator access control alongside the Schindler system. For more details including prerequisites and configuration, please read AN - 196 - Security Expert Schindler HLI Integration
NOTE: Security Expert Software v 4.1.180 or higher is required. SX Controller Firmware v 2.08.919 or higher is required.
One Security Expert Schindler Elevator High Level Interface License (SX-ELV-HLI-SC) per controller is required.
  • EcoStruxure Security Expert
  • JamesMorgan22
