Saving Report Sorting Configuration in Security Expert
  • Saving Report Sorting Configuration in Security Expert
  • JohnBoehmer
    JohnBoehmer
  • CraigEl
    CraigEl
  • JamesMorgan
    JamesMorgan
Lieutenant JG JamesMorgan Lieutenant JG
‎2021-07-01 07:26 AM
How can the reports list sort order be changed and saved so that reports are always displayed in a specific order.
EcoStruxure Security Expert
Security Expert Server
  • Reports are printed in order of Database ID by default.
  • There is a need to have this changed to a custom sorting order.
This video demonstrates how to create, configure and save report layouts in Security Expert.
1. Create your report
     In Security Expert Client menu, go to Reports --> Setup--> User
  • Add and name the new report
  • Choose a Report Type and give your Report a Title
    (this will appear at the header of your report)
  • Skip sorting properties
  • Save your report
2. Add Columns to your report
  • With your new report highlighted, go to the "Columns" tab
  • Click Add to add desired columns for your report
  • Save your report
3. Configure your report:
  • Return to the "General" tab and click "Edit in report view" as seen below
  • Filtering: right-click the column you want to filter and select filter editor
  • Add your desired filters
  • Apply to view changes and OK to close the editor
  • Sorting: right-click the column(s) you want to sort
  • Click Save Report Filter to save your changes
Note:
1. You can clear custom sorting of the report table by::
  • Right-click tab and hit clear sorting
2. You can also filter multiple columns:
  • Right-click the columns
  • Sort primary column (Dept, Access Level, Region)
  • Sort secondary columns
  • EcoStruxure Security Expert
Tags (7)
  • edit
  • filter
  • JamesMorgan21
  • JamesMorgan23
  • reports
  • Security Expert Client
  • sorting
