SUM Alarm used to monitor the status of the system Automation Servers
  • SUM Alarm used to monitor the status of the system Automation Servers
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • Benji
    Benji
  • sesa125819
    sesa125819
‎2018-09-10 02:01 PM
Last Updated: Kirk Mahmoud_Sayed Kirk ‎2024-08-07 03:21 AM
The SUM Alarm does not generate an alarm when an Automation Server goes offline
  • Building Operation Enterprise Central
  • Building Operation Automation Server
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
  • Building Operation Edge Server - Standard
The online status of the Automation Servers needs to be monitored so that an alarm can be generated if any of them go offline. Using the following configuration does not work.
1. Create a sum alarm
2. Add Source and set to AS path (e.g /SWXnetwork/servers/AS1). Replacing AS1 with a * makes no difference
3. Add System alarm ID and set to "Server Offline"
4. Add Alarm State and set to "Selection as required"
Options that do work
Option 1
System Alarm ID = Server offline
Alarm Text = */Servers/*
Alarm State = Alarm and Alarm Acknowledge - (Select as required).
Option 2
  • System Alarm ID = Server offline
  • Alarm State = Alarm and Alarm Acknowledge - (Select as required).
  • Source Name = AS1 or AS*
Option 3
  • Source = /SWXnetwork/System/Server Communication/To/AS* - (As the alarm is in the ES, the path comes from the ES).
Tags (2)
  • 18502
  • MahmoudSayed24
75% helpful (3/4)
