SEC-TE/SED-0 does not join the MPM’s ZigBee network and does not go online
Select a Country
  • SEC-TE/SED-0 does not join the MPM’s ZigBee network and does not go online
  • SaidSawan
    SaidSawan
  • CraigEl
    CraigEl
‎2018-09-06 09:35 AM
Last Updated: CraigEl Champion ‎2022-08-11 08:18 PM
SEC-TE (TE2) smart terminal controller / SED-0 (DA2) smart wireless actuator will not come online in an MPM controller.
EcoStruxure Building Expert, Field Devices
  • SmartStruxure Lite Multi-Purpose Manager
  • Smart Controllers
The Zigbee network configuration parameters in the MPM have been entered incorrectly.
The application version of the SEC-TE/SED-0 must be determined before proceeding forward. Sticker on device should read V13 or V14.
To check/modify the current settings, navigate to the "ZigBee Configuration" object (ZBC) under the MPM.
For Application Version 13: Stack profile should be set to "Custom" and Security profile should be set to "None."
For Application Version 14: Stack profile should be set to "ZigBee Pro" and Security profile should be set to "Home Automation."
Labels (2)
  • EcoStruxure Building Expert
  • Field Devices
Tags (4)
  • 16430
  • mpm-gw.
  • mpm-un
  • mpm-va
