SE7000/SE8000 Room Controller does not join the ZigBee network
Select a Country
  • SE7000/SE8000 Room Controller does not join the ZigBee network
  • SaidSawan
    SaidSawan
  • CraigEl
    CraigEl
  • Sacco
    Sacco
‎2018-09-10 02:14 PM
Last Updated: CraigEl Champion ‎2022-08-08 10:51 PM
The ZigBee network configuration parameters (Channel and PAN ID) of the MPM matches those of the room controller, but the room controller will not come online.
Symptoms:
  • For SE(R)8000 Series: The "ZigBee Short" field in the "Network" menu option keeps changing.
  • For SE(R)7000 Series: The Green LED is blinking twice where 3 blinks are expected. (Description of LED status defined in LED status for SE7000 Room Controller ZigBee communication module)
EcoStruxure Building Expert, Field Devices
  • SmartStruxure Lite Multi-Purpose Manager
  • SE8xxx Room controller
  • SE8000 Series
  • SER8300, SE8300, SE8350
  • Viconics branding VT8000 Series
A temporary bug causes the MPM to prevent a specific ZigBee com module (installed inside the room controller) from joining the network on a particular channel.
MPM has to be reset using one of the following methods
Method 1: Unplug and replug power to the MPM
Method 2: Click on the "Restart Controller" button as shown in image below. Note: Database must be saved before restarting the controller to avoid loss of data.
Labels (2)
  • EcoStruxure Building Expert
  • Field Devices
Tags (5)
  • 16433
  • flash
  • flashes
  • flashing
  • mpm-gw
0% helpful (0/1)
