Replacing Satchwell Sensors with Schneider Electric part numbers
  • Replacing Satchwell Sensors with Schneider Electric part numbers
  • sesa139513
    sesa139513
  • PaulFr
    PaulFr
  • DavidChild
    DavidChild
  • Dave_Shore
    Dave_Shore
  • CraigEl
    CraigEl
‎2018-09-11 01:37 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 10:57 PM
Field Devices
Sensors
Cross referencing older 'T' type sensors to the current version.
  • Outside Sensor DOT2301 , DOT0001, DOT0002 is now STO600
  • Immersion Pipe Sensor DWT1701 (125mm), DWT1702 (200mm), DWT0001 is now STP660 (note, if replacing sensor only then DWA0001 required).
  • Strap On/Pipe Contact Sensor DST1601 , DST0001 is now STC600
  • Duct Sensor (mainly FCUs) DDU1803 , DDU0001 is now STD670
  • Duct Sensor DDT1701 (300mm) , DDT1702 (460mm) , DDT0001 is now STD660
  • Room Sensor DRT3453 (sensor only, no setpoint adjust) is now STR600
  • For other DR and DRT sensors see Replacements for Satchwell sensors
  • Drayton Room Sensor A701 is now STR600D
  • Drayton Outside Sensor A702 is now STO600D
  • Drayton Immersion Sensor A703 is now STP600D
  • Drayton Strap On / Contact Sensor A704 is now STC600D
  • Field Devices
Tags (4)
  • 12900
  • 5252
  • 5352
  • csc
