Replacements for Satchwell sensors
  • Replacements for Satchwell sensors
‎2020-09-29 10:29 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:54 AM
Satchwell MicroNet, Satchwell Sigma, Field Devices
DR
  • DR3253
DRT
  • DRT3451
  • DRT3453
  • DRT4453
  • DRT3651
  • DRT3652
  • DRT3801
  • DRT3851
DU
  • DU4301
DUS
  • DUS4302
DUSF
  • DUSF4351
  • DUSF4352
DRTE
  • DRTE2201
  • DRTE2801
  • DRTE2851
DRH
  • DRH7702
  • DRH7703
DRTH
  • DRTH7712
  • DRTH7713
DOT
  • DOT0001
  • DOT0002
DOS
  • DOS0002
DDT
  • DDT1701
Replacements for Satchwell Room sensors
DOT0001/0002
  • Outside temperature sensor
  • For CSC, KMC, MMC, IAC, MNN
  • New part number: STO600/5126060000
DOS0002
  • Outside solar sensor
  • New part number:  SSO600/5126050000
DR3253
  • Room sensor non-adjustable
  • For SVT
  • New part number: STR614/004604900
DRT3451
  • Room sensor exposed adjustment
  • For CZU, CSC
  • New part number: STR612/004604700
DRT3452
  • Room sensor concealed adjustment
  • For CZU, CSC
  • New part number: STR611/004604600
DRT3453
  • CZU, CSC, CXR, CZT, KMC, MMC, IAC, MNN
  • New part number: STR600/004604100
DRT4451
  • As DRT 3453 in S-Link housing
  • Obsolete with no Schneider Electric replacement
  • Suggestions: Try Titan Products or Sontay
DRT3651
  • Room temperature sensor exposed adjustment
  • For CXR, CZT, KMC, MMC, IAC, MNN
  • New part number: STR602/004604300
DRT3652
  • Room temperature sensor exposed + LED
  • For MMC, IAC, MNN
DRT3801
  • Room temperature sensor fan switch
  • On/off for CZU, MNN, IAC
DRT3851
  • Room temperature sensor fan speed switches
  • As above plus medium and high
DU4301
  • Room sensor temperature
  • For MNN & URC
  • New part number: STR601/004604200
DUS4302
  • Room sensor temperature setpoint advanced
  • basic sensor
  • New part number: STR613/004604800
DUSF4351
  • Room sensor temperature setpoint adjustable fan
  • auto/on/off fan override
  • New part number: STR609/004604400
DUSF4352
  • Room sensor temperature setpoint advanced fan
  • Auto/1/2/3 fan override
  • New part number: STR610/004604500
DRTE2201
  • Active room detector
  • Basic sensor
DRTE2801
  • On/off
DRTE2851
  • Off/low/medium/high
DRH7702
  • 2% 0-10V DC humidity only
  • For KMC, MMC, IAC, MNN
  • New part number: SHR100/006902340
DRH7703
  • 3% 0-10V DC humidity only
DRTH7712
  • 2% 0-10V DC humidity with Satchwell
  • NTC TEMP OUTPUT For KMC, MMC, IAC, MNN
  • New part number: SHR100-T6/006902420
DRTH7713
  • 3% 0-10V DC humidity with Satchwell NTC temperature output
DDT
  • DDT1701, DDT1702 and DDT0001
  • Duct sensor non-adjustable
  • New part number: STD660 5126030000
Contact Details:
  • Titan Controls: http://www.titancontrols.net/
  • Sontay Controls https://www.sontay.com
Labels (3)
  • Field Devices
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
Tags (3)
  • 5213
  • DavidChild20
  • GaryMontague20
100% helpful (1/1)
