Replacement of obsolete Satchwell TR Series 230 V ac / 24 V ac Transformer by S-E TR Series 230 V ac / 24 V ac Transformer
  • Replacement of obsolete Satchwell TR Series 230 V ac / 24 V ac Transformer by S-E TR Series 230 V ac / 24 V ac Transformer
  • Gary
    Gary
  • DavidChild
    DavidChild
  • sesa139513
    sesa139513
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-07 02:58 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 11:36 PM
Satchwell TR Series 230 V ac / 24 V ac Transformer requires replacement.
Field Devices
Satchwell TR1 (25VA), TR2 (50VA), TR3 (80VA), TR4 (200VA) and TR5 (300VA) 230 V ac / 24 V ac Transformers.
Obsolescence of Satchwell TR1, TR2, TR3, TR4 and TR5 230 V ac / 24 V ac Transformers.
  1. Replace Satchwell 871-1-201 TR1 (25VA) 230 V ac / 24 V ac Transformer with S-E TR 32 (32VA) 230 V ac / 24 V ac Transformer SE part number 3413032000.
  2. Replace Satchwell 871-1-202 TR2 (50VA) 230 V ac / 24 V ac Transformer with S-E TR 60 (60VA) 230 V ac / 24 V ac Transformer SE part number 3413060000.
  3. Replace Satchwell 871-1-203 TR3 (80VA) 230 V ac / 24 V ac Transformer with Transformer of another manufacturer's origin.
  4. Replace Satchwell 871-1-204 TR4 (200VA) 230 V ac / 24 V ac Transformer with Transformer of another manufacturer's origin.
  5. Replace Satchwell 871-1-205 TR5 (300VA) 230 V ac / 24 V ac Transformer with Transformer of another manufacturer's origin.
The S-E TR range of Transformers provide the same functionality as the Satchwell TR range of Transformers but differ in appearance, dimensions and the range of VA ratings available.
Specification EN 60742, with which the Satchwell range of Transformers complied, has been superseded by Specification EN 61558, with which the S-E range of Transformers comply.
To review the transformer data sheet, see TR32-60 Transformer Data sheet en [101917].pdf.
  • Field Devices
  • 3280
