Replace an old Xenta 301 system version 1 with a new controller
  • Replace an old Xenta 301 system version 1 with a new controller
‎2018-09-11 12:51 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:55 AM
You need to replace a faulty Xenta 301 controller. However, the existing unit is running System Version 1, and the network comprises approximately 12 Xenta controllers on a Menta-only network using the .nwc and .ndb configuration tools.
TAC Vista
TAC Xenta 300
New Xenta 301 controllers are shipped with System Version 3 by default. System Versions 1 and 3 are incompatible on the same network.
To ensure compatibility, downgrade the new Xenta 301 controller to System Version 1.17 before installation.
Steps to Downgrade and Replace:
  1. Download TAC Xenta 300 system program version 1.17
    • Use the Download Wizard as usual.
    • Important: When downgrading from Version 3 to Version 1, do NOT retain the old application in the Download Wizard.
    • Select "Clear Application" during the process.
  2. Manually Download the Menta Application and Network Configuration
    • Use a serial cable to perform the manual download.
    • Apply the appropriate TAC Menta versions for your network setup.
Additional Notes
  • Mixing different system versions on the same network can lead to unpredictable behavior and communication issues.
  • Always verify the version compatibility before deploying new hardware.
Tags (2)
  • 12460
  • JonasBrissman25
