Remote Alarm Manager - What TCP ports are used?
  • Remote Alarm Manager - What TCP ports are used?
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
  • sesa125819
    sesa125819
‎2018-09-06 11:00 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-12 08:45 PM
The RAM Console is unable to communicate with the RAM Engine, and/or the customer cannot access the RAM Webserver.
Satchwell BAS & Sigma
Remote Alarm Manager (RAM)
This issue typically occurs when the required TCP ports used by the Remote Alarm Manager are blocked, misconfigured, or not open on the network or firewall.
To ensure proper communication between RAM components, verify that the following TCP ports are open and correctly configured:
Communication Path Default TCP Port(s) Notes
RAM Console ↔ RAM Engine 8090, 8091 Required for internal communication between the console and engine.
RAM Webserver 80 Default HTTP port.
RAM Webserver (Recommended Range) 781–785 Recommended to change from port 80 to a port within this range.
🔧 Tip: You can configure the recommended port range (781–785) in the RAM settings page to enhance security and avoid conflicts with other services using port 80.
Additional Information
  • Ensure your firewall and network policies allow traffic through the specified ports.
  • If using custom ports, update all relevant configurations in both the RAM Console and RAM Engine.
  • Refer to Resolving Possible Port Conflicts
Labels (3)
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
Tags (2)
  • 11406
  • CraigEllis25
100% helpful (1/1)
