Remote Alarm Manager – “Stop transmission of the Alarm Message” Setting May Be Lost
  • Remote Alarm Manager – “Stop transmission of the Alarm Message” Setting May Be Lost
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-11 03:52 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 11:14 PM
In Remote Alarm Manager (RAM) 2.0, the “Stop transmission of the Alarm Message” setting within an Action may be unintentionally lost when reviewing or modifying the configuration. This setting is part of the “What should be done when an alarm is acknowledged” menu.
Satchwell BAS & Sigma, Satchwell MicroNet, TAC Vista
The issue arises due to the way the Action configuration is navigated. Depending on the method used to review or edit the Action, the setting may be deselected without user awareness.
There are two methods to modify an Action, each with different implications:
  1. Sequential Navigation (Using “Next” Button):
    • Open the Action and proceed through each page using the Next button until reaching Finish.
    • If you repeat this process, the “Stop transmission of the Alarm Message” option may become deselected, even if it was previously enabled.
  2. Direct Page Selection (Using Left-Side Navigation):
    • Open the Action and directly select the desired page using the navigation boxes on the left.
    • Important: If this method is used, always verify that the “Stop transmission of the Alarm Message” checkbox is ticked before clicking Finish.
Best Practice Tip:
When modifying Actions in RAM, always double-check the status of the “Stop transmission of the Alarm Message” setting before finalizing changes. This ensures alarm behavior remains consistent and avoids unintended message transmission.
Labels (3)
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
Tags (2)
  • 13188
  • CraigEllis25
