Region and Language settings are not the same when TAC Vista is running as a Service
  • Region and Language settings are not the same when TAC Vista is running as a Service
  • Jonas_Brissman
    Jonas_Brissman
  • RobertAndriolo
    RobertAndriolo
  • MikaelKrantz
    MikaelKrantz
‎2018-09-11 08:25 AM
Last Updated: Janeway Jonas_Brissman Janeway ‎2024-11-19 04:54 AM
Why do we get different settings when TAC Vista is running as a Service compare to started normally?
TAC Vista
Vista Server
When TAC Vista is running as a Service, it is using "System user", and not the same user that is logged in.
Verify that the system user have correct settings to be able to run TAC Vista as a Service.
Under Region and Language, under the tab Administrative, you find Current language for non-Unicode programs, and also a button named Change system locale...
Tags (3)
  • 17861
  • JonasBrissman24
  • services
