Recommendation for cores and memory setup for PCT
  • Recommendation for cores and memory setup for PCT
  • JohnBoehmer
    JohnBoehmer
  • StephenYang
    StephenYang
  • JonGreen
    JonGreen
Admiral StephenYang Admiral
‎2019-10-31 07:50 AM
PCT core and memory setup documentation does not exist
Building Operation Project Configuration Tool (PCT)
It is unclear what PCT core and memory settings should be configured for different kind of projects.
  • For optimal use, the minimum recommendation “Cores” should be limited to four (4), and have two (2) GB of “Memory” allocated
  • Should you notice your CPU usage increase past 75%, the number of Cores can be increased as needed to help stabilize the system and maintain efficiency.
  • Additional memory can be allocated for larger projects with many AS’s or multiple users working on the project at the same time. The amount of memory will be limited by the available memory on the machine, and the memory allocated to all the projects that are running.
Labels (2)
  • Project Configuration Tool
  • StephenYang19
