Receive a connection error when attempting to login to Security Expert.
  • Receive a connection error when attempting to login to Security Expert.
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
‎2018-09-10 09:30 AM
Last Updated: Picard RobertAndriolo Picard ‎2021-05-02 06:00 PM
When attempting to log in the below network errors, or similar, are displayed.
  1. Connect: The server was unable to process the request due to an internal error.
  2. Could not log on to Server. Please check your remote connection setup
    Further checking the Windows Application Event logs on the Server you may also find error messages similar to the below being logged against the Security Expert services.
    CDTNames::GetTagName : Cannot open database "SecurityExpert" requested by the login. The login failed.
EcoStruxure Security Expert
  • Security Expert
  • MS SQL
The Security Expert services do not have the correct credentials to access the SecurityExpert database.
  1. Confirm the user account that the Security Expert services are using in Windows.
    1. Go to Start > Run > and type "Services.msc".
    2. Confirm the account that those services are being run under. By default, and in the example, this is the Local System account.
  2. Run Microsoft SQL Server Management Studio and under your server browse to Security > Logins.
    1. Find the user account that your services were used in step 1
    2. In the Server Roles page of this user account. Enable the "sysadmin" server role
    3. Save changes and restart the Security Expert services.
  • EcoStruxure Security Expert
Tags (4)
  • 19649
  • AdamSteele20
  • AdamSteele21
  • RobertAndriolo21
