Questions on Sigma backup NiMH batteries.
  • Questions on Sigma backup NiMH batteries.
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 09:52 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 11:38 PM
This article addresses common questions regarding the NiMH battery packs used in Sigma X96 controllers, including:
  1. What is the average shelf life of these batteries?
  2. Can the battery voltage be checked without disconnecting them from the controller?
  3. Is there a recommended preventative maintenance interval for checking the batteries?
Satchwell BAS & Sigma
Sigma UNC controllers
These questions typically arise during routine maintenance or troubleshooting of Sigma controllers, especially when assessing battery health or planning replacements.
  • Battery Shelf Life
    • NiMH cells degrade over time, especially in long-term storage.
    • Typical shelf life: Up to 2 years.
    • Risk: Prolonged storage can lead to internal short circuits, a known characteristic of NiMH chemistry.
  • Measuring Battery Voltage
    • Direct measurement without disconnection is not recommended.
    • If the battery remains connected, the voltage reading will reflect the charge circuit, not the battery itself.
    • Recommended method:
      • Power down the controller completely (turn off both mains and battery switches).
      • Insert multimeter probes into the back of the battery connector to measure voltage.
    • Note: Voltage alone is not a reliable indicator of battery health.
      • For accurate assessment, measure the run-time on battery power or use a commercial battery analyzer.
  • Preventative Maintenance Interval
    • No fixed interval is officially specified.
    • Why? Battery lifespan is influenced by several factors, especially ambient temperature.
    • Best practice: Monitor battery performance periodically and replace if degradation is observed.
  • Satchwell BAS & Sigma
Tags (2)
  • 15004
  • CraigEllis25
