Project Configuration Tool (PCT) fails to run with Error "VM Module INITIALIZING_ Failed to refresh versions"
  • Project Configuration Tool (PCT) fails to run with Error "VM Module INITIALIZING_ Failed to refresh versions"
  • Reza
    Reza
  • RandyDavis
    RandyDavis
  • CraigEl
    CraigEl
  • Miche
    Miche
Lt. Commander Reza Lt. Commander
‎2022-05-31 11:46 AM
Last Updated: Administrator CraigEl Administrator ‎2023-07-12 06:44 PM
The user installed the PCT on a machine and after running it, the following error pops up: “VM Module INITIALIZING_ Failed to refresh versions”
Building Operation Project Configuration Tool (PCT)
An installed and enabled antivirus may have corrupted the PCT installation.
By verifying the PCT Virtual Box logs, we can see the folloiwng error:
ERROR [COM]: aRC=E_FAIL (0x80004005) aIID={xxxx-xxxx-xxxxx-xxxx-xxxx} aComponent={MachineWrap} aText={The virtual machine 'Project Name' has terminated unexpectedly during startup with exit code -1073741819 (0xc0000005)}, preserve=false aResultDetail=0
This indicates that the antivirus may have corrupted the PCT installation if it remained enabled during the installation. Now the PCT cannot communicate with the Virtual Machine.
To resolve this, users will need to re-install the PCT while the antivirus has been disabled temporarily.
Labels (2)
  • RezaAmirzadeh22
50% helpful (1/2)
