Procedure for replacing a Continuum BCX 4040 controller
  • Procedure for replacing a Continuum BCX 4040 controller
  • David_Kendrick
    David_Kendrick
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:12 PM
Last Updated: Sisko GavinHe Sisko ‎2023-06-05 03:06 AM
What is the correct procedure for replacing a Continuum bCX 4040 controller
Andover Continuum
  • CyberStation
  • bCX 4040
Considering both Continuum and BACnet 'sides' replacing a bCX4040 can seem a complicated process.
  1. Commission new/replacement bCX through its default webpage just as the as old bCX except for the BACnet Configurable Properties section.
  2. Set the BACnet Device ID = The same ID in the old bCX (serial number of controller by default)
  3. Set the BACnet Port Number UDP = same as old bCX (BAC0 by default)
  4. Set the BACnet Network ID UDP = same as old bCX (1 by default)
  5. Set the BACnet Network ID Comm2 = same as old bCX (2765 by default)
  6. Set the BACnet MAC ID Comm2 = Same as old bCX (0 by default)
  7. Set the BACnet MS/TP Enhanced Mode = Same as old bCX (TRUE by default)
  8. Set BACnet BBMD Enabled/Disabled = Same as old bCX (False by default)
  9. Bring the bCX online in Continuum Explorer,
  10. Select menu item Options | Send to Controller options
  11. Select "Reload attached objects, but not attached controllers" - select ok
  12. Verify the bCX Comm2 settings and baud rate speeds.
  13. In Continuum Explorer, right click on the bCX and perform a "send to controller"
  14. Verify points and communications.
Tags (2)
  • 4472
  • DavidKendrick23
50% helpful (2/4)
