Problems backing up a database after an upgrade to 2.13
  • Problems backing up a database after an upgrade to 2.13
  • Ramaaly
    Ramaaly
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 02:53 PM
Last Updated: Lt. Commander Ramaaly Lt. Commander ‎2023-04-03 08:26 AM
TAC INET
I/NET Seven rev 2.13
  1. Shut down I/NET and I/O Server
  2. Start DB Create, select the option to Upgrade Database
  3. Force an upgrade to the database.
  4. Select Verify Database, to ensure that there are no differences.
  5. Start I/O Configuration, modify the active profile, hit the OK button, and don’t make any changes. Close it again.
  6. Start I/Net again and verify that all I/NET functions are normal.
  7. Shut down I/NET and I/O Server again.
  8. Start DB Create and verify that all the functions are available to you again.
  • TAC INET
Tags (2)
  • 2815
  • RamaAly23
