Periodic report will not run when Vista Server is running as a service
  • Periodic report will not run when Vista Server is running as a service
  • CraigEl
    CraigEl
  • SESA116857
    SESA116857
‎2018-09-10 12:55 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 02:06 AM
Errors in Vista Workstation alarm window:
"Failed to execute report XXXXX-YYYY, Error in "DDE Execute" command[27]"
"Warning logged in B0WARLOG.TXT on node XXXXXX"
Contents of B0WARLOG.TXT:
"Could not open report XXXXX-YYYY, hRes=[-2147467261]Invalid pointer"
TAC Vista
  • Vista Server
  • Microsoft Windows 7
  • Microsoft Windows Server 2008
Vista Server does not support running as a service under the local system or interactive user account. A PC account that has local administrator rights must be used to run Vista Server.
Follow the registration instructions for Vista Server in Registering/Unregistering TAC Vista Server as a Windows service when registering TACOS.exe as a service.
  • 5896
