PCT doesn't update "Added to parent" column after detaching child server
  • PCT doesn't update "Added to parent" column after detaching child server
Admiral StephenYang Admiral
‎2019-11-26 01:33 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:35 AM
The added to parent column shows incorrect information.
PCT 1.X
Added to paretns screen edited.png PCT 2.x
Building Operation Project Configuration Tool (PCT)
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
PCT doesn't detect detachment in WorkStation.
Do not detach the child server from its parent in PCT 1.x and 2.x.
Webhelp information: Adding a Virtual EcoStruxure BMS Child Server to a Parent Server.
Labels (2)
  • Project Configuration Tool
Tags (4)
  • its*
  • RezaAmirzadeh22
  • StephenYang19
  • StephenYang25
50% helpful (1/2)
