PCT 1.x Connection Issue Error: "Get System State Command: 'Could not connect' "
Select a Country
  • PCT 1.x Connection Issue Error: "Get System State Command: 'Could not connect' "
  • Taylor_Leach
    Taylor_Leach
  • CraigEl
    CraigEl
  • StephenYang
    StephenYang
  • Jonathan
    Jonathan
‎2018-09-10 07:17 AM
Last Updated: CraigEl Champion ‎2024-01-16 05:33 PM
This condition will arise after successfully installing and running Project Configuration Tool for some time. PCT 1.x can no longer initialize the virtual host adapter as a result of the adapter being deleted or removed.
The errors may be a result of but not limited to:
  1. Introducing a new VPN software package to your PC/Laptop.
  2. Manually removing or modifying the Virtual Box Host Only - Network Adapter.
  3. Malware or Antivirus platforms that have removed or disabled the adapter.
Example:
PCT Version - 1.1.2.57 Local mode was set up on a physical laptop and used to offline engineer a project. The job was completed and PCT was not used again for roughly a month.
A new project was sold and required PCT for offline engineering. The laptop was booted up and PCT failed to open. The user was presented with the following errors:
  • "Get System State Command: 'Could not connect' "
  • "Get predefined properties command: 'Could not connect' "
  • "GetDashboardErrors Command: 'Could not connect' "
  • "Get System Memory info Command: 'Could not connect' "
  • Windows Client versions (64 Bit Only)
  • Windows Server versions (64 Bit Only)
  • PCT SERVER versions (64 Bit OS Only)
  • Project Configuration Tool 1.x
PCT 1.x can no longer initialize the virtual host adapter as a result of the Vbox adapter being deleted or removed.
Reinstall PCT 1.x on top of your current installation. Your projects will not be modified in the process.
  1. Locate the installer.
  2. Run the installer, it will ask you to remove the previous version. Press ok.
  3. Progress will show as uninstalling.
  4. PCT will prompt for installation. Click Next.
  5. Select default installation paths. Click Next.
  6. Select desired PCT mode. Click next.
  7. Ready to Install selected mode. Click Next.
  8. PCT software installed. Click Finish.
  9. Now PCT will set up the Virtual Host Adapter. Press Ok.
  10. Status bar.
  11. Compted setup dialog. Click Ok.
  12. Run PCT. If successful you will see the template sets getting installed via the top right of the window.
  13. Open a project and test an AS/AS-P.
If the above steps do not work, here are a few more to try:
  • Restart the machine after the PCT software finishes re-installing
  • Right-click and select “Run as Administrator”
  • Uninstall PCT software and Oracle VirtualBox and re-install once more
If PCT 1.x still will not work, please open a support case with your local Product Support Group.
Tags (5)
  • 19840
  • project configuration tool
  • StephenYang24
  • TaylorLeach19
  • vbox
65% helpful (9/14)
