Opening Customer's Sigma Data Files in Sigma on Another Computer
  • Opening Customer's Sigma Data Files in Sigma on Another Computer
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • Gary
    Gary
‎2018-09-11 06:55 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-10 08:09 PM
Sigma data files from one computer are being opened on another computer with a different Sigma version, potentially causing system instability or data corruption.
Satchwell BAS & Sigma
Satchwell Sigma
Sigma data files are version-dependent. When a specific Sigma version is installed, only data files created or used with that same version should be accessed. Copying the entire Sigma folder from one version to another may appear to work but can introduce hidden issues due to background tasks and version mismatches.
  • Do not copy the entire Sigma folder from one version to another system.
  • Avoid restoring files that were accessed on a different Sigma version back onto the customer’s machine.
  • Use virtual machines to host different Sigma versions if multiple versions are needed for support or testing.
  • Refer to the article “How to Identify the Sigma Version Installed on a Computer” for guidance on matching release and build numbers.
  • Satchwell BAS & Sigma
Tags (2)
  • 15614
  • CraigEllis25
