Only 1 personnel record processes when using the Personnel Import Utility (PIU)
  • Only 1 personnel record processes when using the Personnel Import Utility (PIU)
  • Alan_Wood
    Alan_Wood
  • CraigEl
    CraigEl
‎2018-09-11 06:53 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:47 PM
A message indicates only one Personnel record processed when using the PIU
Andover Continuum
  • Continuum
  • Windows XP
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
By default the CSVtoContinuumTransformation.xsl transform file sets the alias column to concatenate (TAC + SerialNumber).
The transform needs to be edited in a text editor (not IE) to change the concatenate line to be a unique alias.
Example:
(Before) This displays the alias records in the preview as TAC
< select="concat(‘TAC’, SerialNumber) " value-of="">
(After) This will import the records correctly
< select="concat(‘TAC’, EmpNumber) " value-of="">
If all was working at one point and the site was upgraded then the old PC may have the CSVtoContinuumTransformation.xsl that was working. If this is a new install, select a number that will be unique for the records.
For more information on editing the PIU see the following article: Personnel Import Utility documentation
  • 13999
