No beep when presenting a card in front of an HID reader
  • No beep when presenting a card in front of an HID reader
  • David_Kendrick
    David_Kendrick
  • CraigEl
    CraigEl
  • YangboLIU
    YangboLIU
‎2018-09-06 09:56 AM
Last Updated: Admiral David_Kendrick Admiral ‎2023-06-20 04:50 AM
When swiping a card in front of the reader, there should be a beep indicating that the reader has read the card. There is no beep.
EcoStruxure Security Expert, Andover Continuum, TAC I/NET
  • Access Control
  • HID Reader
There are 3 possible reasons for this issue:
  • The beeper is disabled through a default configuration when the card is shipped
  • The beeper has failed
  • The Reader and Card represent incompatible technologies such as an 125Khz Prox Reader trying to read a 13.56MHz IClass Card
  1. Ensure Reader and Card both support a common technology (125Khz/13.56Mhz etc..)
  2. Short the Beeper wire (yellow) and the GND wire (Black) with the reader powered On
  3. If there is a beep, that indicates that the beeper can work but is disabled.
    • Ask the manufacturer to send a configuration card to enable the beeper (use 3 seconds after reader power is on)
  4. If shorting the beeper produces no sound, the beeper has failed.
    • Send the reader to repair and replace it with a new one.
Labels (3)
  • EcoStruxure Security Expert
  • TAC INET
Tags (2)
  • 14783
  • DavidKendrick23
