No Offline Controller Email Generated by Access Expert
  • No Offline Controller Email Generated by Access Expert
  • Roger_Bently
    Roger_Bently
‎2018-09-06 07:59 AM
When a controller goes Offline, no email is being generated from the system when set up.
Access Expert
  • Access Expert
  • Server2012
  • SQL2012 R2
  • Hosted Instance
  • Premise Instance
There is no email server set up in the User interface for the system to use.
To resolve this issue please follow these steps:
  1. On the General Configuration tab, click on System Settings
  2. Verify these settings or use the default
  3. Click on User Interface Tab
  4. Use a valid email address e.g. Name@Domain.com
  5. Verify that the system is generating the email by Triggering an Alarm  e.g (Controller Disconnected Long Time)
  • EcoStruxure Access Expert
  • 19270
