New PCT installation will not allow Server Packages to be added.
  • New PCT installation will not allow Server Packages to be added.
  • JohnBoehmer
    JohnBoehmer
  • CraigEl
    CraigEl
  • JonGreen
    JonGreen
JohnBoehmer Schneider Alumni (Retired)
‎2021-11-18 07:15 AM
Last Updated: Administrator CraigEl Administrator ‎2023-07-12 06:46 PM
When adding Server Packages to a new PCT install, the installation process does not complete.
Building Operation Project Configuration Tool (PCT)
Some security policy is interfering with the PCT installation process.
The VirtualBoxDisclamer.log shows the following error
Could not add PCTService to BUILTIN\Administrators.
The lack of the PCTService could be responsible for a range of issues including the failure to install Server Packages.
To learn what is preventing the creation of the PCTService, try manually adding the user to the Administrators group to see what errors might be presented.
Open Windows event log and look for errors that occurred during the same timeframe noted above.
Labels (2)
  • Project Configuration Tool
67% helpful (2/3)
